Little deFormer 2
Little deFormer 2
Little deFormer 2
4 Voices
16 Parts
1
1 VCA with ADSR envelope
32-track, 32-step sequencer
512 Patches (RAM)
Sampler -
Sat, 10/03/2020 - 09:08
deFormer 2
Little deFormer 2 User Manual
Gotherman
http://www.vintagesynth.com/Gotharmans/littledformer2
Today 07:14 AM
Arturia update the AstroLab
Today 07:14 AM
Today 07:14 AM
Today 07:14 AM
fedDSP release quadCHO
Today 07:14 AM
Today 07:14 AM
Today 07:14 AM
Brooklyn Synth & Pedal Expo October 17-1...
Today 07:14 AM
Teenage Engineering Opens Store In New Y...
Today 07:14 AM
