Little deFormer 2
Little deFormer 2
Little deFormer 2
4 Voices
16 Parts
1
1 VCA with ADSR envelope
32-track, 32-step sequencer
512 Patches (RAM)
Sampler -
Sat, 10/03/2020 - 09:08
deFormer 2
Little deFormer 2 User Manual
Gotherman
http://www.vintagesynth.com/Gotharmans/littledformer2
Today 06:38 PM
Today 06:38 PM
Today 06:38 PM
Mike Beigel: 1947–2026
Today 06:38 PM
Baby Audio announce HyperWarp
Today 06:38 PM
Today 06:38 PM
Arturia update the AstroLab
Today 06:38 PM
Cheap Studio Hardware With A Professiona...
Today 04:04 PM
Scanner: Library – Raiders of the Lost T...
Today 04:04 PM
