Little deFormer 2
Little deFormer 2
Little deFormer 2
4 Voices
16 Parts
1
1 VCA with ADSR envelope
32-track, 32-step sequencer
512 Patches (RAM)
Sampler -
Sat, 10/03/2020 - 09:08
deFormer 2
Little deFormer 2 User Manual
Gotherman
http://www.vintagesynth.com/Gotharmans/littledformer2
Cherry Audio Pentaphonic – The Power of ...
Today 01:42 PM
Arturia’s AstroLab Family Receives 2.0 U...
Today 01:42 PM
Today 01:42 PM
Today 01:42 PM
Today 12:39 PM
UDO Audio DMNO ON: How Many Knobs Would ...
Today 12:39 PM
fedDSP release quadCHO
Today 12:39 PM
Today 12:39 PM
Today 12:39 PM
