Little deFormer 2
Little deFormer 2
Little deFormer 2
4 Voices
16 Parts
1
1 VCA with ADSR envelope
32-track, 32-step sequencer
512 Patches (RAM)
Sampler -
Sat, 10/03/2020 - 09:08
deFormer 2
Little deFormer 2 User Manual
Gotherman
http://www.vintagesynth.com/node/13591
PWM Preferences!
Today 11:45 AM
Baby Audio announce HyperWarp
Today 11:45 AM
Today 11:45 AM
Arturia update the AstroLab
Today 11:45 AM
Today 11:45 AM
Today 11:45 AM
fedDSP release quadCHO
Today 11:45 AM
Today 11:45 AM
Today 10:20 AM
