Little deFormer 2
Little deFormer 2
Little deFormer 2
4 Voices
16 Parts
1
1 VCA with ADSR envelope
32-track, 32-step sequencer
512 Patches (RAM)
Sampler -
Sat, 10/03/2020 - 09:08
deFormer 2
Little deFormer 2 User Manual
Gotherman
http://www.vintagesynth.com/node/13591
Today 08:04 PM
Today 08:04 PM
Today 08:04 PM
Cherry Audio Revives Rare Gleeman Pentap...
Today 08:04 PM
Suzanne Ciani On Buchla Instruments & Mo...
Today 08:04 PM
Today 07:10 PM
Mike Beigel: 1947–2026
Today 07:10 PM
Baby Audio announce HyperWarp
Today 07:10 PM
Today 07:10 PM
