Nord Wave
Nord Wave
Nord Wave
18 voices
2 parts
Pulse, Triangle, Saw, Sine
180 MB Flash Memory
Thu, 01/30/2020 - 10:03
2008
Clavia Nord Wave
Nord wave demo
Marko Volk
Anthares
Today 03:46 PM
iFi audio reveal the GR2 MT
Today 03:46 PM
Today 03:46 PM
Today 03:46 PM
Today 03:46 PM
Today 03:46 PM
Today 03:46 PM
The Best Value Offset Guitars 2026: Jagu...
Today 02:01 PM
The Best Audio Interfaces of 2026: Incre...
Today 02:01 PM
