Nord Wave
Nord Wave
Nord Wave
18 voices
2 parts
Pulse, Triangle, Saw, Sine
180 MB Flash Memory
Thu, 01/30/2020 - 10:03
2008
Clavia Nord Wave
Nord wave demo
Marko Volk
Anthares
iFi audio reveal the GR2 MT
Today 08:21 PM
Today 08:21 PM
Today 06:44 PM
Today 06:44 PM
Today 06:44 PM
Today 06:44 PM
Today 06:44 PM
Strymon launch the La Brea
Today 06:44 PM
Sync Audio release MegaMorph
Today 06:44 PM
