Nord Wave
Nord Wave
Nord Wave
18 voices
2 parts
Pulse, Triangle, Saw, Sine
180 MB Flash Memory
Thu, 01/30/2020 - 10:03
2008
Clavia Nord Wave
Nord wave demo
Marko Volk
Anthares
Black Rooster Audio launch PS-VC1 Vocal ...
Today 05:35 PM
Dr. Fill from Yurt Rock
Today 05:35 PM
Parish Audio introduce Parametric Compre...
Today 04:40 PM
Rapid Flow release miniGRID
Today 04:40 PM
Love Synthesizers announce First Love pr...
Today 04:40 PM
Neyrinck revive Avid D-Control surfaces
Today 04:40 PM
SoundBridge's TURN server tutorial
Today 04:40 PM
Audio Modeling open PolySWAM pre-orders
Today 04:40 PM
Minimal Audio release Lucid
Today 04:40 PM
