Nord Wave
Nord Wave
Nord Wave
18 voices
2 parts
Pulse, Triangle, Saw, Sine
180 MB Flash Memory
Thu, 01/30/2020 - 10:03
2008
Clavia Nord Wave
Nord wave demo
Marko Volk
Anthares
Scintillate, VxBx, Parrot: Free Plugins ...
Today 04:39 AM
Celebrating the SEM Filter: 5 Ways to Ge...
Today 04:39 AM
Today 04:39 AM
Today 04:39 AM
VAEMI announce the Synterra
Today 04:39 AM
AudioRoute from Arvital Audio
Today 04:39 AM
Today 04:39 AM
SSL 360° gets a major update
Today 04:39 AM
Boris FX reveal Sequoia 2026.5
Today 04:39 AM
