Nord Wave
Nord Wave
Nord Wave
18 voices
2 parts
Pulse, Triangle, Saw, Sine
180 MB Flash Memory
Thu, 01/30/2020 - 10:03
2008
Clavia Nord Wave
Nord wave demo
Marko Volk
Anthares
Today 11:31 AM
UVI Falcon 2027 Flies The Nest with More...
Today 11:31 AM
ADAM Audio Sub10 PRO and Sub8 PRO: 2 New...
Today 11:31 AM
Teenage Engineering Wants to Stop Making...
Today 11:31 AM
Sync Audio release MegaMorph
Today 11:31 AM
Today 11:31 AM
Today 11:31 AM
Today 11:31 AM
Today 11:31 AM
