Nord Wave
Nord Wave
Nord Wave
18 voices
2 parts
Pulse, Triangle, Saw, Sine
180 MB Flash Memory
Thu, 01/30/2020 - 10:03
2008
Clavia Nord Wave
Nord wave demo
Marko Volk
Anthares
Rapid Flow release omniGRID
Yesterday 07:31 PM
Yesterday 06:32 PM
Positive Grid announce the Spark Pedal
Yesterday 06:32 PM
Arturia launch the AudioFuse Studio Rev2
Yesterday 05:24 PM
Neumann launch the KH 310 II & KH 350
Yesterday 05:24 PM
Readipop & XOX open XOX Studio
Yesterday 05:24 PM
Acon Digital introduce Acoustica 8
Yesterday 05:24 PM
Bjooks Beat Gems to begin shipping
Yesterday 05:24 PM
Sonarworks Autumn Sale
Yesterday 05:24 PM
