GR-300 - Printable Version +- Vortex Sound Research (http://www.n01ze.com/synthwizards/Forum) +-- Forum: N01ZE World Net News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=45) +--- Forum: World Wide Gear News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=2) +--- Thread: GR-300 (/showthread.php?tid=8206) |
GR-300 - SynthWizard - 12-09-2019 GR-300 <div><span>GR-300</span> <div class="field field--name-field-specifications field--type-double-field-extended field--label-above"> <div class="field--label">Specifications</div> <div class="field__items"> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Polyphony" data-content="The number of voices (notes) a device can produce simultaneously. Typically, a monophonic device can only play one note at a time. A Duophonic device can play two notes at a time. A polyphonic device can play two or more notes at a time." data-placement="top" data-trigger="hover" data-toggle="popover">Polyphony - </span> <span class="specification-value">6 voices</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Oscillators" data-content="An electronic device which generates a periodic signal of a particular frequency, usually a sine wave, but sometimes a square wave or other waveform. In an analog synthesizer, oscillators typically produce regularly repeating fluctuations in voltage - that is, they oscillate. In digital synthesis, an oscillator more typically plays back a complex waveform by reading the numbers in a wavetable." data-placement="top" data-trigger="hover" data-toggle="popover">Oscillators - </span> <span class="specification-value">2 oscillators per voice</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Modulation" data-content="The process of sending a control signal to a sound source so as to change the character of the sound." data-placement="top" data-trigger="hover" data-toggle="popover">Modulation - </span> <span class="specification-value">-24 dB per octave, with envelope modulation</span> </div> </div> </div> </div> <span><a title="View user profile." href="http://www.vintagesynth.com/user/406" lang="" about="http://www.vintagesynth.com/user/406" typeof="schema erson" property="schema:name" datatype="" xml:lang="">Naomi Bolton</a></span><span>Tue, 11/26/2019 - 12:07</span> <div class="field field--name-body field--type-text-with-summary field--label-hidden field--item"><p>The GR-300 is an analog guitar synthesizer released by Roland Corporation back in 1980 and continued to be one of the best pieces of analog guitar synthesis equipment for a long time. Roland advertised the GR-300 as a synthesizer that is able to produce effects and nuances that were impossible for the keyboard synthesizers of the time to easily produce. In fact, in order to produce the effects delivered by this synth you would actually need six octave shifters, six compressors, six chorus machines, six distortion units, six phase shifters and much more. Best of all, the major functions of the GR-300 are all controlled via your feet switches, which means you don't even have to use your hands to operate it. Not bad for a synth that can produce anything from simple or complex solo sounds to huge band or orchestra sounds. Of course, this also meant that the GR-300 was great for live performances. Also, it's possible to connect attachments between the GR-300 and an external amplifier, so you can use chorus, flangers, phase shifters and any other devices designed to work with synths.<br><br> What set the GR-300 apart from the competition was the fact that it could produce stable effects for virtually all styles of guitar playing. This includes hammering, chopping, harmonics, glissandos and more. This is something that was impossible to accomplish before the release of the GR-300. This was a big step up from the GR-500, it's predecessor, which suffered from serious tracking issues that limited its usefulness. The only thing that you had to keep in mind was to keep any fluorescent lamps, neon lights, and high power transformers away from the GR-300 as these would produce high noise levels in the synth.<br><br> The GR-300 has a rugged appearance, which is good for something that is going to be on the floor most of the time. In terms of features and specifications, this synth offers 6-voice polyphony, 2 oscillators per voice and VCOs that are directly harmonically locked to each string. However, these can still be tuned separately as well. It has an LFO for vibrato effects and can output either the guitar, the synth, or a mix of these two. One of the most notable users of the Roland GR-300 is Pat Metheny, but other notable users include Andy Summers (The Police), Robert Fripp and Adrian Belew (King Crimson), and Pete Townshend (The Who).</p></div> <div class="field field--name-field-make-er field--type-entity-reference field--label-above"> <div class="field--label">Make</div> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/841" hreflang="en">Roland</a></div> </div> <div class="field field--name-field-year field--type-integer field--label-above"> <div class="field--label">Year</div> <div class="field--item">1980</div> </div> <div class="field field--name-field-musical-genre-er field--type-entity-reference field--label-above"> <div class="field--label">Musical genre</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/776" hreflang="en">Pop, Rock & HipHop</a></div> </div> </div> <div class="field field--name-field-synth-type-er field--type-entity-reference field--label-above"> <div class="field--label">Synth type</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/778" hreflang="en">Analog</a></div> </div> </div> <div class="field field--name-field-interface-features-er field--type-entity-reference field--label-above"> <div class="field--label">Interface features</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/783" hreflang="en">Vintage</a></div> </div> </div> <div class="field field--name-field-format-er field--type-entity-reference field--label-above"> <div class="field--label">Format</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/788" hreflang="en">Desktop / Tabletop</a></div> </div> </div> <div class="field field--name-field-sound-types-er field--type-entity-reference field--label-above"> <div class="field--label">Sound types</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/794" hreflang="en">Synth effects</a></div> </div> </div> <div class="field field--name-field-price-range-er field--type-entity-reference field--label-above"> <div class="field--label">Price range</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/796" hreflang="en">$500 to $1,000</a></div> </div> </div> <div class="field field--name-field-image-er field--type-image field--label-above"> <div class="field--label">Image</div> <div class="field--item"> <img src="http://www.vintagesynth.com/sites/default/files/2019-10/GR-300.jpg" width="1600" height="1159" alt="Roland GR-300" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="field field--name-field-files field--type-entity-reference-revisions field--label-above"> <div class="field--label">Files</div> <div class="field__items"> <div class="field--item"> <div class="file-item"> <a href="http://cdn.roland.com/assets/media/pdf/GR-300_OM.pdf" class="file-title">Roland Polyphonic Guitar Synthesizer GR-300 Owner's Manual </a><span class="file-description">Roland Polyphonic Guitar Synthesizer GR-300 Owner's Manual </span> </div> </div> </div> </div> <div class="field field--name-field-youtube field--type-entity-reference-revisions field--label-above"> <div class="field--label">YouTube</div> <div class="field__items"> <div class="field--item"> <div class="youtube-field" data-pid="16976"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/I3PFu99KvYo.jpg" alt="Embedded thumbnail for GR-300 > YouTube (previous revision)" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Roland GR-300 Function Test - Part One</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item">WayneJoness</div> </div> </div> </div> </div> <div class="field--item"> <div class="youtube-field" data-pid="16981"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/f8_6KwmJcyk.jpg" alt="Embedded thumbnail for GR-300 > YouTube" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Vintage Roland G303 guitar and Gr300 Synthesizer demo</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item">Marco Tiraboschi</div> </div> </div> </div> </div> </div> </div> <div class="field field--name-field-user-rating field--type-vs-synth-rating field--label-above"> <div class="field--label">User Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="85cd3400-d32f-4e5b-8a74-1d2e9fd2f4cc"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-texture field--type-list-string field--label-above"> <div class="field--label">Texture</div> <div class="field--item">Polyphonic instruments</div> </div> <div class="field field--name-field-disqus-comment field--type-disqus-comment field--label-above"> <div class="field--label">Disqus comment</div> <div class="field__items"> <div class="field--item"><drupal-render-placeholder callback="Drupal\disqus\Element\Disqus::displayDisqusComments" arguments="0=GR-300&1=http%3A//www.vintagesynth.com/roland/gr-300&2=node/12936" token="MfLal2mO7AdPVOP6JXOogvgBWXsKFLf_ZzSid4_QH8k"></drupal-render-placeholder></div> </div> </div></div> http://www.vintagesynth.com/roland/gr-300 |
