Malekko Heavy Industry Corporation Manther - Printable Version +- Vortex Sound Research (http://www.n01ze.com/synthwizards/Forum) +-- Forum: N01ZE World Net News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=45) +--- Forum: World Wide Gear News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=2) +--- Thread: Malekko Heavy Industry Corporation Manther (/showthread.php?tid=31963) |
Malekko Heavy Industry Corporation Manther - SynthWizard - 02-10-2022 Malekko Heavy Industry Corporation Manther <span>Malekko Heavy Industry Corporation Manther</span> <div class="field field--name-field-specifications field--type-double-field-extended field--label-above"> <div class="field--label">Specifications</div> <div class="field__items"> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Polyphony" data-content="The number of voices (notes) a device can produce simultaneously. Typically, a monophonic device can only play one note at a time. A Duophonic device can play two notes at a time. A polyphonic device can play two or more notes at a time." data-placement="top" data-trigger="hover" data-toggle="popover">Polyphony - </span> <span class="specification-value">1 Voice</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Oscillators" data-content="An electronic device which generates a periodic signal of a particular frequency, usually a sine wave, but sometimes a square wave or other waveform. In an analog synthesizer, oscillators typically produce regularly repeating fluctuations in voltage - that is, they oscillate. In digital synthesis, an oscillator more typically plays back a complex waveform by reading the numbers in a wavetable." data-placement="top" data-trigger="hover" data-toggle="popover">Oscillators - </span> <span class="specification-value">VCO with Pulse (with PWM), Sawtooth, Triangle (with Waveshaper)</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Filter" data-content="A type of equalizing device for subtractively eliminating selected frequencies from the sound spectrum of a signal and perhaps, in the case of a resonant filter, increasing the level of other frequencies." data-placement="top" data-trigger="hover" data-toggle="popover">Filter - </span> <span class="specification-value">Low pass filter with resonance</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="LFO" data-content="Low Frequency Oscillator. An oscillator especially devoted to applications below the audible frequency range, and typically used as a control source for modulating a sound to create vibrato, tremolo, trills, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">LFO - </span> <span class="specification-value">1 LFO with sine, rectangle, sawtooth, ramp and random</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Envelopes" data-content="A shape that changes as a function of time. The shape of a synthesizer's envelope is often controlled by Attack, Decay, Sustain and Release parameters (ADSR). Envelopes can be applied to various aspects of a synth sound, such as pitch, filter cutoff frequency, and overall amplitude." data-placement="top" data-trigger="hover" data-toggle="popover">Envelopes - </span> <span class="specification-value">ADSR envelopes for VCA and VCF</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Controls" data-content="On-board rotary knobs, linear sliders, and push-buttons or switches that may be used to edit various parameters." data-placement="top" data-trigger="hover" data-toggle="popover">Controls - </span> <span class="specification-value">MIDI In/Out</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Sequencer" data-content="A hardware device, software application or module used to arrange/sequence timed events into musical patterns and songs. An analog sequencer uses control voltages and gate triggers to control vintage analog devices. A digital sequencer usually uses MIDI and has more advanced capabilities than an analog sequencer." data-placement="top" data-trigger="hover" data-toggle="popover">Sequencer - </span> <span class="specification-value">64-step sequencer</span> </div> </div> </div> </div> <span><a title="View user profile." href="https://www.vintagesynth.com/user/406" lang="" about="https://www.vintagesynth.com/user/406" typeof="schema erson" property="schema:name" datatype="" xml:lang="">Naomi Bolton</a></span><span>Fri, 01/14/2022 - 08:56</span> <div class="field field--name-body field--type-text-with-summary field--label-hidden field--item"><p>Manther is a full-featured tabletop synthesizer from the Portland, Oregon-based Malekko Heavy Industry Corporation. It is a monosynth with an analog signal path and features an advanced 64-step digital sequencer as well as onboard delay. The biggest selling point for the Manther is its CEM3340 based VCO IC chip, and its analog filter is also based on an SSM2044 chip. The CEM3340 is quite coveted and featured in everything from the Roland SH-101 and Sequential Prophet 5 to the Oberheim OB-8 and OB-Xa. The SSM2044 is also a classic in its own right and was used in everything from the Korg Monopoly to the Polysix. In addition, Manther has a Source Mixer giving users total control over the square, triangle, saw, tri shape, noise and sub levels, and waveforms, including individual outputs.</p> <p>Thanks to the digital sequencer, each step can be automated across all mean features. It can also save all automation within a total of 64 presets. Songs can be built by simply selecting the presets that you want to play in any order. The keyboard with transpose controls can be used to quickly program notes, and Repeat and Probability functions can be utilized per step. To set up the more complex features, users can make use of the menu, which also offers additional control. It covers everything from Sub Semitones and the ADSR envelope to sequence direction, sequence division and multiplication, LFO phase, and much more.</p> <p>In terms of inputs and outputs, Manther was designed with 3.5mm jacks on top of the enclosure. These are for use with Eurorack modules, but it can also be linked with other external gear over MIDI by making use of the two rear MIDI jacks. From left to right, it has LFO Output, VCO CV Input, Sequencer CV Output, Sequencer Gate Output, Individual outputs for square wave, saw wave, and triangle wave, analog clock input and outputs, external audio input, MIDI input and output, VCF CV input, headphone output, VCA CV input, and envelope gate input. Finally, the rear panel also hosts the power in and power on/off button.</p> <p>Overall, the Manther is a very straightforward and easy-to-use synthesizer. It is a very versatile monosynth and offers plenty of sequencer possibilities. The interface also makes it great for users who want a hands-on experience. There are cheaper alternatives to this synthesizer, but it is a very inspirational bit of gear in terms of sound and functionality.</p> </div> <div class="field field--name-field-make-er field--type-entity-reference field--label-above"> <div class="field--label">Make</div> <div class="field--item"><a href="https://www.vintagesynth.com/taxonomy/term/1211" hreflang="en">Malekko Heavy Industry Corporation</a></div> </div> <div class="field field--name-field-musical-genre-er field--type-entity-reference field--label-above"> <div class="field--label">Musical genre</div> <div class="field__items"> <div class="field--item"><a href="https://www.vintagesynth.com/taxonomy/term/776" hreflang="en">Pop, Rock & HipHop</a></div> </div> </div> <div class="field field--name-field-synth-type-er field--type-entity-reference field--label-above"> <div class="field--label">Synth type</div> <div class="field__items"> <div class="field--item"><a href="https://www.vintagesynth.com/taxonomy/term/778" hreflang="en">Analog</a></div> </div> </div> <div class="field field--name-field-interface-features-er field--type-entity-reference field--label-above"> <div class="field--label">Interface features</div> <div class="field__items"> <div class="field--item"><a href="https://www.vintagesynth.com/taxonomy/term/784" hreflang="en">Modern</a></div> </div> </div> <div class="field field--name-field-format-er field--type-entity-reference field--label-above"> <div class="field--label">Format</div> <div class="field__items"> <div class="field--item"><a href="https://www.vintagesynth.com/taxonomy/term/788" hreflang="en">Desktop / Tabletop</a></div> </div> </div> <div class="field field--name-field-sound-types-er field--type-entity-reference field--label-above"> <div class="field--label">Sound types</div> <div class="field__items"> <div class="field--item"><a href="https://www.vintagesynth.com/taxonomy/term/790" hreflang="en">Synthetic</a></div> </div> </div> <div class="field field--name-field-price-range-er field--type-entity-reference field--label-above"> <div class="field--label">Price range</div> <div class="field__items"> <div class="field--item"><a href="https://www.vintagesynth.com/taxonomy/term/796" hreflang="en">$500 to $1,000</a></div> </div> </div> <div class="field field--name-field-image-er field--type-image field--label-above"> <div class="field--label">Image</div> <div class="field--item"> <img src="https://www.vintagesynth.com/sites/default/files/2022-01/manther.jpg" width="2224" height="1112" alt="Malekko Heavy Industry Corporation Manther" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="field field--name-field-links field--type-link field--label-above"> <div class="field--label">Links</div> <div class="field__items"> <div class="field--item"><a href="https://soundcloud.com/malekkoheavyindustry/malekko-manther-audio-1">Soundcloud - Malekko - Manther Audio 1</a></div> </div> </div> <div class="field field--name-field-files field--type-entity-reference-revisions field--label-above"> <div class="field--label">Files</div> <div class="field__items"> <div class="field--item"> <div class="file-item"> <div class="field field--name-field-link field--type-link field--label-above"> <div class="field--label">Link</div> <div class="field--item"><a href="https://malekkoheavyindustry.com/content/uploads/2018/06/MALEKKO-MANTHER-MANUAL-V1.03.pdf">https://malekkoheavyindustry.com/content/uploads/2018/06/MALEKKO-MANTHER-MANUAL…</a></div> </div> <div class="field field--name-field-type field--type-list-string field--label-above"> <div class="field--label">Type</div> <div class="field--item">File</div> </div> <div class="field field--name-field-title field--type-string field--label-above"> <div class="field--label">Title</div> <div class="field--item">MANTHER MANUAL</div> </div> <div class="field field--name-field-description field--type-string-long field--label-above"> <div class="field--label">Description</div> <div class="field--item">Malekko Heavy Industry Corporation Manther Manual</div> </div> </div> </div> </div> </div> <div class="field field--name-field-youtube field--type-entity-reference-revisions field--label-above"> <div class="field--label">YouTube</div> <div class="field__items"> <div class="field--item"> <div class="youtube-field" data-pid="18286"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="https://www.vintagesynth.com/sites/default/files/youtube/cDRwI5eTADM.jpg" alt="Embedded thumbnail for Malekko Heavy Industry Corporation Manther > YouTube" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Malekko Manther - 1-Hour Sound Test (Sound Demo)</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item"> Daniel Dehaan</div> </div> </div> </div> </div> </div> </div> <div class="field field--name-field-user-rating field--type-vs-synth-rating field--label-above"> <div class="field--label">User Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="df66bb56-70aa-4708-851b-afa288c99463"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="https://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="https://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="https://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="https://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="https://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-texture field--type-list-string field--label-above"> <div class="field--label">Texture</div> <div class="field--item">Monophonic instruments</div> </div> <div class="field field--name-field-disqus-comment field--type-disqus-comment field--label-above"> <div class="field--label">Disqus comment</div> <div class="field__items"> <div class="field--item"><drupal-render-placeholder callback="Drupal\disqus\Element\Disqus::displayDisqusComments" arguments="0=Malekko%20Heavy%20Industry%20Corporation%20Manther&1=https%3A//www.vintagesynth.com/malekko/heavy_industry_corporation_manther&2=node/14436" token="fl8OsBAgaIFMfEWTXRFjdxjmnIYlRSR5mFgy8v4NukA"></drupal-render-placeholder></div> </div> </div> https://www.vintagesynth.com/malekko/heavy_industry_corporation_manther |
