Nord Stage 2 - Printable Version +- Vortex Sound Research (http://www.n01ze.com/synthwizards/Forum) +-- Forum: N01ZE World Net News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=45) +--- Forum: World Wide Gear News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=2) +--- Thread: Nord Stage 2 (/showthread.php?tid=27282) |
Nord Stage 2 - SynthWizard - 10-01-2021 Nord Stage 2 <div><span>Nord Stage 2</span> <div class="field field--name-field-specifications field--type-double-field-extended field--label-above"> <div class="field--label">Specifications</div> <div class="field__items"> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Polyphony" data-content="The number of voices (notes) a device can produce simultaneously. Typically, a monophonic device can only play one note at a time. A Duophonic device can play two notes at a time. A polyphonic device can play two or more notes at a time." data-placement="top" data-trigger="hover" data-toggle="popover">Polyphony - </span> <span class="specification-value">18 Voices</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Multitimbral" data-content="A synthesizing instrument that can play two or more timbres (also called sounds or patches) at the same time. A typical multitimbral tone generator can play, for example, the brass, piano, and violin parts all at once." data-placement="top" data-trigger="hover" data-toggle="popover">Multitimbral - </span> <span class="specification-value">2-part multitimbral</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Waveforms" data-content="A signal, either sampled (digitally recorded) or periodic, being generated by an oscillator. Also, the graphical display of a sound pressure wave over time." data-placement="top" data-trigger="hover" data-toggle="popover">Waveforms - </span> <span class="specification-value">Wavetable synthesis with 62 waveforms / analog synthesis with multiple waveforms</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="LFO" data-content="Low Frequency Oscillator. An oscillator especially devoted to applications below the audible frequency range, and typically used as a control source for modulating a sound to create vibrato, tremolo, trills, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">LFO - </span> <span class="specification-value">LFO with square, triangle, ramp and sample & hold</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Controls" data-content="On-board rotary knobs, linear sliders, and push-buttons or switches that may be used to edit various parameters." data-placement="top" data-trigger="hover" data-toggle="popover">Controls - </span> <span class="specification-value">MIDI In/Out, USB</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Arpeggiator" data-content="A device that steps from note to note for whichever keys are pressed (or latched) in a preset or random pattern." data-placement="top" data-trigger="hover" data-toggle="popover">Arpeggiator - </span> <span class="specification-value">Up, Down, Up-Down and Random, Range: 1, 2, 3, or 4 octaves</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Effects" data-content="Any form of audio signal processing that provides reverbs, delays, chorus, and other audio and spatial effects to sweeten, liven and animate audio as well as to create the sound of a space or environment." data-placement="top" data-trigger="hover" data-toggle="popover">Effects - </span> <span class="specification-value">Effect 1, Effect 2, Delay, 3 types of speaker simulations, tube amp simulation, rotary speaker, compressor, reverb</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Keyboard" data-content="A set of keys or levers, arranged in order of ascending pitch, which enables a piano, organ or synthesizer to be played by hand." data-placement="top" data-trigger="hover" data-toggle="popover">Keyboard - </span> <span class="specification-value">HA88/Ha76-models: Hammer Action Weighted Keyboards | SW73-model: 73-note Semi Weighted Waterfall keyboard</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Memory" data-content="Storage capabilities for user programmed settings, patches, sequences, waveforms, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">Memory - </span> <span class="specification-value">500 megabyte memory for piano sounds / 380 megabytes of sample memory / 300 patch memory locations</span> </div> </div> </div> </div> <span><a title="View user profile." href="http://www.vintagesynth.com/user/406" lang="" about="http://www.vintagesynth.com/user/406" typeof="schema ![]() <span>Fri, 09/10/2021 - 10:41</span> <div class="field field--name-body field--type-text-with-summary field--label-hidden field--item"><p>The Nord Stage 2 was released by Clavia in 2011 as the successor to the Nord Stage from 2005 and Nord Stage Ex from 2008. It improved on previous versions with more piano sample memory as well as synth sample memory and increased synth polyphony. Clavia released three different Nord Stage 2 models, with the differences being the number of keys and compatible accessories. The models are the Nord Stage 2 HA88, Nord Stage 2 HA76, and Nord Stage 2 SW73.</p> <p> </p> <p>The Nord Stage 2 is a serious digital piano, and while it is user-friendly, it is not aimed at beginners. The design of the Stage 2 harkens back to the early synthesizers thanks to its red finish and the multitude of buttons. It features Organ, Synthesizer, and Piano sounds, which can be used simultaneously. Up to two sounds from each section can also be combined in a single program for users who desire even greater sonic flexibility.</p> <p> </p> <p>The piano section features state-of-the-art sample-based acoustic pianos along with advanced vintage electric pianos and is Nord Piano Library compatible. The synth section features powerful classic analog, FM, wavetable synthesis, sample playback, an arpeggiator, and a master clock. In addition, it is compatible with the Nord Sample Library for even more options. Finally, the organ section features B3 tonewheel organ modeling, accurate simulations of the classic Voc and Farfisa organs, and an advanced rotary speaker model. The latter has slow, fast, and stop modes. This section also has draw buttons with LED bar graphs for an easy overview of the active drawbar settings.</p> <p> </p> <p>Other global features of the Nord Stage 2 include a comprehensive effects section, single-function control knobs, and instant visibility of current settings. Each of the three sections has its own dedicated sound generators and controls, so there's no need for deep menus or complicated screens to navigate. The Extern Section of the Nord Stage 2 was designed solely to control external devices with ease. This is in line with its purpose of being a master keyboard. Both the HA88 and HA76 feature a fully weighted Hammer Action keyboard, while the SW73 has a 73-note Semi-Weighted Waterfall keyboard. In keeping with Nord tradition, the instruments were assembled at their Stockholm factory, where every keybed was individually and specifically tuned. This allowed for consistent response and balance across instruments.</p> <p> </p> <p>The Nord Stage 2 was a flagship instrument when it was first released and still holds up well, although it has been surpassed by the Nord Stage 2 EX and Stage 3. While it doesn't deviate too much from the design of the original Nord Stage, Clavia addressed all the issues users had and made quite a few improvements in key areas. This used to be the go-to stage piano for anyone searching for a high-performance and quality instrument and remains coveted by many.</p></div> <div class="field field--name-field-make-er field--type-entity-reference field--label-above"> <div class="field--label">Make</div> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/873" hreflang="en">Clavia</a></div> </div> <div class="field field--name-field-year field--type-integer field--label-above"> <div class="field--label">Year</div> <div class="field--item">2009</div> </div> <div class="field field--name-field-musical-genre-er field--type-entity-reference field--label-above"> <div class="field--label">Musical genre</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/776" hreflang="en">Pop, Rock & HipHop</a></div> </div> </div> <div class="field field--name-field-synth-type-er field--type-entity-reference field--label-above"> <div class="field--label">Synth type</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/779" hreflang="en">Digital</a></div> </div> </div> <div class="field field--name-field-interface-features-er field--type-entity-reference field--label-above"> <div class="field--label">Interface features</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/784" hreflang="en">Modern</a></div> </div> </div> <div class="field field--name-field-format-er field--type-entity-reference field--label-above"> <div class="field--label">Format</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/786" hreflang="en">Keyboard</a></div> </div> </div> <div class="field field--name-field-sound-types-er field--type-entity-reference field--label-above"> <div class="field--label">Sound types</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/791" hreflang="en">Acoustic / Realistic</a></div> </div> </div> <div class="field field--name-field-price-range-er field--type-entity-reference field--label-above"> <div class="field--label">Price range</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/797" hreflang="en">Above $1,000</a></div> </div> </div> <div class="field field--name-field-image-er field--type-image field--label-above"> <div class="field--label">Image</div> <div class="field--item"> <img src="http://www.vintagesynth.com/sites/default/files/2021-09/NordClaviaPic.jpg" width="1200" height="424" alt="Clavia Nord Stage 2" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="field field--name-field-files field--type-entity-reference-revisions field--label-above"> <div class="field--label">Files</div> <div class="field__items"> <div class="field--item"> <div class="file-item"> <a href="https://www.nordkeyboards.com/sites/default/files/files/downloads/manuals/nord-stage-2/Nord%20Stage%202%20English%20User%20Manual%20v1.7x%20Edition%20J.pdf" class="file-title">Nord Stage 2 User Manual</a><span class="file-description">User Manual - Nord Stage 2 HA/SW</span> </div> </div> </div> </div> <div class="field field--name-field-youtube field--type-entity-reference-revisions field--label-above"> <div class="field--label">YouTube</div> <div class="field__items"> <div class="field--item"> <div class="youtube-field" data-pid="18256"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/M4rXhyyvERM.jpg" alt="Embedded thumbnail for Nord Stage 2 > YouTube (previous revision)" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Nord Stage 2 - Demo (Full version)</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item"> nordkeyboards</div> </div> </div> </div> </div> <div class="field--item"> <div class="youtube-field" data-pid="18261"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/DgBspQ-d1YU.jpg" alt="Embedded thumbnail for Nord Stage 2 > YouTube" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Nord Stage 2 Demo - Call Me Maybe</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item"> Darren Wetherilt</div> </div> </div> </div> </div> </div> </div> <div class="field field--name-field-user-rating field--type-vs-synth-rating field--label-above"> <div class="field--label">User Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="ad95e218-c19f-45c1-974d-c45828d28fe2"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-vse-rating field--type-list-integer field--label-above"> <div class="field--label">VSE Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="6d304a16-5af5-48df-91b9-e9a509dbbf6d"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-texture field--type-list-string field--label-above"> <div class="field--label">Texture</div> <div class="field--item">Polyphonic instruments</div> </div> <div class="field field--name-field-disqus-comment field--type-disqus-comment field--label-above"> <div class="field--label">Disqus comment</div> <div class="field__items"> <div class="field--item"><drupal-render-placeholder callback="Drupal\disqus\Element\Disqus::displayDisqusComments" arguments="0=Nord%20Stage%202&1=http%3A//www.vintagesynth.com/clavia/nord_stage_2&2=node/14246" token="B3dUPwMk4_gNyGpWMmRWUj4MW0k3IE04NfurgbGPV0U"></drupal-render-placeholder></div> </div> </div></div> http://www.vintagesynth.com/clavia/nord_stage_2 |
