Vermona Mono Lancet - Printable Version +- Vortex Sound Research (http://www.n01ze.com/synthwizards/Forum) +-- Forum: N01ZE World Net News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=45) +--- Forum: World Wide Gear News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=2) +--- Thread: Vermona Mono Lancet (/showthread.php?tid=23732) |
Vermona Mono Lancet - SynthWizard - 05-07-2021 Vermona Mono Lancet <div><span>Vermona Mono Lancet</span> <div class="field field--name-field-specifications field--type-double-field-extended field--label-above"> <div class="field--label">Specifications</div> <div class="field__items"> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Polyphony" data-content="The number of voices (notes) a device can produce simultaneously. Typically, a monophonic device can only play one note at a time. A Duophonic device can play two notes at a time. A polyphonic device can play two or more notes at a time." data-placement="top" data-trigger="hover" data-toggle="popover">Polyphony - </span> <span class="specification-value">1 Voice</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Multitimbral" data-content="A synthesizing instrument that can play two or more timbres (also called sounds or patches) at the same time. A typical multitimbral tone generator can play, for example, the brass, piano, and violin parts all at once." data-placement="top" data-trigger="hover" data-toggle="popover">Multitimbral - </span> <span class="specification-value">1 Part</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Oscillators" data-content="An electronic device which generates a periodic signal of a particular frequency, usually a sine wave, but sometimes a square wave or other waveform. In an analog synthesizer, oscillators typically produce regularly repeating fluctuations in voltage - that is, they oscillate. In digital synthesis, an oscillator more typically plays back a complex waveform by reading the numbers in a wavetable." data-placement="top" data-trigger="hover" data-toggle="popover">Oscillators - </span> <span class="specification-value">1 VCO</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Waveforms" data-content="A signal, either sampled (digitally recorded) or periodic, being generated by an oscillator. Also, the graphical display of a sound pressure wave over time." data-placement="top" data-trigger="hover" data-toggle="popover">Waveforms - </span> <span class="specification-value">Saw Down, Saw Up, Square, Triangle,</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Slope" data-placement="top" data-trigger="hover" data-toggle="popover">Slope - </span> <span class="specification-value">24dB Slope (4-pole)</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="LFO" data-content="Low Frequency Oscillator. An oscillator especially devoted to applications below the audible frequency range, and typically used as a control source for modulating a sound to create vibrato, tremolo, trills, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">LFO - </span> <span class="specification-value">1 LFO with Sample & Hold, Saw Up, Saw Down, Square, Triangle</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="VCA" data-content="Voltage controlled amplifier. A device that responds to a change in voltage at its control input by altering the gain of a signal being passed through it." data-placement="top" data-trigger="hover" data-toggle="popover">VCA - </span> <span class="specification-value">1 VCA with ADSR</span> </div> </div> </div> </div> <span><a title="View user profile." href="http://www.vintagesynth.com/user/406" lang="" about="http://www.vintagesynth.com/user/406" typeof="schema erson" property="schema:name" datatype="" xml:lang="">Naomi Bolton</a></span><span>Thu, 05/06/2021 - 09:33</span> <div class="field field--name-body field--type-text-with-summary field--label-hidden field--item"><p>The Mono Lancet '15 is an analog monophonic synthesizer from the German-based Vermona. This two-oscillator synth features an ADSR envelope as well as one LFO and has a distinctively retro look. It is built like a tank, though, and everything about it feels very sturdy despite its compact size. The metal chassis has a two-tone color design while the star-shaped knobs are cream in color. The entire unit also tilts forward slightly, which is a design choice that makes it easier to see the text for the knob functions.</p> <p>The back of this desktop synth features both MIDI In and Thru ports along with the audio out and an expansion socket. The 12V power supply socket is also on the rear of this synth, but the "Overkill" button is slightly more puzzling. While the manual stresses that it is not a power switch, it pretty much fulfills the same function.</p> <p>On the front panel, there are three rows of controls with the top section reserved for the VCO's. Along with three-octave switches for each oscillator, there are also knobs for "Detune", "Glide", "LFO INT" and more. The second row is dedicated to the VCF and VCA knobs. Here there is a three-position switch to toggle between the EG, gate, or always on as well as "SEQ" and "TRIG" buttons. Finally, the bottom row of knobs is split into segments for the VCO with a master "Tune" knob, the LFO, and the EG with the ADSR knobs. The overall look of the Lancet is functional, but not exactly exciting. Nevertheless, it gets the job done and is easy to use at a glance. The large knobs of this synth are also perfect for precise adjustments.</p> <p>In terms of sound, the Lancet has a lot in common with the Vermona Perfourmer, which means with some tweaking you can get some classic Moog sounds from it too. Small mono synths are a dime a dozen these days, but the Lancet still manages to impress with its punchy envelope and creamy filter. Its filter section features a 24dB low-pass filter that is capable of self-oscillating, so users can expect a remarkably stable sine wave with a 2 1/2 octave range. In addition, the cutoff frequency can be controlled via MIDI. The Lancet comes out on top when compared to other synths in the same price range, such as the Doepfer Dark Energy.</p> <p>Overall, if you are looking for a mono synth with a warm sound and rugged build quality you can't go wrong with the Vermona Mono Lancet.</p> </div> <div class="field field--name-field-year field--type-integer field--label-above"> <div class="field--label">Year</div> <div class="field--item">2010</div> </div> <div class="field field--name-field-musical-genre-er field--type-entity-reference field--label-above"> <div class="field--label">Musical genre</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/775" hreflang="en">Electronic music</a></div> </div> </div> <div class="field field--name-field-synth-type-er field--type-entity-reference field--label-above"> <div class="field--label">Synth type</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/778" hreflang="en">Analog</a></div> </div> </div> <div class="field field--name-field-interface-features-er field--type-entity-reference field--label-above"> <div class="field--label">Interface features</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/783" hreflang="en">Vintage</a></div> </div> </div> <div class="field field--name-field-format-er field--type-entity-reference field--label-above"> <div class="field--label">Format</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/788" hreflang="en">Desktop / Tabletop</a></div> </div> </div> <div class="field field--name-field-sound-types-er field--type-entity-reference field--label-above"> <div class="field--label">Sound types</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/790" hreflang="en">Synthetic</a></div> </div> </div> <div class="field field--name-field-price-range-er field--type-entity-reference field--label-above"> <div class="field--label">Price range</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/796" hreflang="en">$500 to $1,000</a></div> </div> </div> <div class="field field--name-field-image-er field--type-image field--label-above"> <div class="field--label">Image</div> <div class="field--item"> <img src="http://www.vintagesynth.com/sites/default/files/2021-04/Monolancet.jpg" width="679" height="505" alt="Vermona Mono Lancet" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="field field--name-field-files field--type-entity-reference-revisions field--label-above"> <div class="field--label">Files</div> <div class="field__items"> <div class="field--item"> <div class="file-item"> <div class="field field--name-field-link field--type-link field--label-above"> <div class="field--label">Link</div> <div class="field--item"><a href="https://www.vermona.com/fileadmin/user_upload/products/ml15/downloads/ml15_manual_en.pdf">https://www.vermona.com/fileadmin/user_upload/products/ml15/downloads/ml15_manu…</a></div> </div> <div class="field field--name-field-type field--type-list-string field--label-above"> <div class="field--label">Type</div> <div class="field--item">File</div> </div> <div class="field field--name-field-title field--type-string field--label-above"> <div class="field--label">Title</div> <div class="field--item">Mono Lancet ’15 User Guide</div> </div> <div class="field field--name-field-description field--type-string-long field--label-above"> <div class="field--label">Description</div> <div class="field--item">User Guide</div> </div> </div> </div> </div> </div> <div class="field field--name-field-youtube field--type-entity-reference-revisions field--label-above"> <div class="field--label">YouTube</div> <div class="field__items"> <div class="field--item"> <div class="youtube-field" data-pid="18051"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/t6eKtxt7G74.jpg" alt="Embedded thumbnail for Vermona Mono Lancet > YouTube (previous revision)" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Vermona Mono Lancet 15 Demo Sounds</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item">Syntza</div> </div> </div> </div> </div> <div class="field--item"> <div class="youtube-field" data-pid="18056"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/2rPOrRNt2hs.jpg" alt="Embedded thumbnail for Vermona Mono Lancet > YouTube" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Vermona Mono Lancet Audio Demonstration (HD) by INHALT</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item"> INHALTVIDEO</div> </div> </div> </div> </div> </div> </div> <div class="field field--name-field-user-rating field--type-vs-synth-rating field--label-above"> <div class="field--label">User Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="10b07b5a-417a-4560-8a28-7f9241842eaa"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-vse-rating field--type-list-integer field--label-above"> <div class="field--label">VSE Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="cdd05d30-63a2-4f8c-b7f6-03738aac1a93"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-texture field--type-list-string field--label-above"> <div class="field--label">Texture</div> <div class="field--item">Monophonic instruments</div> </div> <div class="field field--name-field-disqus-comment field--type-disqus-comment field--label-above"> <div class="field--label">Disqus comment</div> <div class="field__items"> <div class="field--item"><drupal-render-placeholder callback="Drupal\disqus\Element\Disqus::displayDisqusComments" arguments="0=Vermona%20Mono%20Lancet&1=http%3A//www.vintagesynth.com/node/13976&2=node/13976" token="RnIvCv1vRE8uj_dcDMDcWTXri4gb9DwYC-SGH8QeFaQ"></drupal-render-placeholder></div> </div> </div></div> http://www.vintagesynth.com/node/13976 |
