Quantum - Printable Version +- Vortex Sound Research (http://www.n01ze.com/synthwizards/Forum) +-- Forum: N01ZE World Net News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=45) +--- Forum: World Wide Gear News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=2) +--- Thread: Quantum (/showthread.php?tid=23270) |
Quantum - SynthWizard - 04-25-2021 Quantum <div><span>Quantum</span> <div class="field field--name-field-specifications field--type-double-field-extended field--label-above"> <div class="field--label">Specifications</div> <div class="field__items"> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Polyphony" data-content="The number of voices (notes) a device can produce simultaneously. Typically, a monophonic device can only play one note at a time. A Duophonic device can play two notes at a time. A polyphonic device can play two or more notes at a time." data-placement="top" data-trigger="hover" data-toggle="popover">Polyphony - </span> <span class="specification-value">8 Voices</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Multitimbral" data-content="A synthesizing instrument that can play two or more timbres (also called sounds or patches) at the same time. A typical multitimbral tone generator can play, for example, the brass, piano, and violin parts all at once." data-placement="top" data-trigger="hover" data-toggle="popover">Multitimbral - </span> <span class="specification-value">8 Parts</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Oscillators" data-content="An electronic device which generates a periodic signal of a particular frequency, usually a sine wave, but sometimes a square wave or other waveform. In an analog synthesizer, oscillators typically produce regularly repeating fluctuations in voltage - that is, they oscillate. In digital synthesis, an oscillator more typically plays back a complex waveform by reading the numbers in a wavetable." data-placement="top" data-trigger="hover" data-toggle="popover">Oscillators - </span> <span class="specification-value">3 stereo digital oscillators</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Waveforms" data-content="A signal, either sampled (digitally recorded) or periodic, being generated by an oscillator. Also, the graphical display of a sound pressure wave over time." data-placement="top" data-trigger="hover" data-toggle="popover">Waveforms - </span> <span class="specification-value">Pulse Variable, Saw Down, Saw Up, Sine, Square, Triangle, Wave Table, White Noise</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Filter Slopes" data-content="A type of equalizing device for subtractively eliminating selected frequencies from the sound spectrum of a signal and perhaps, in the case of a resonant filter, increasing the level of other frequencies." data-placement="top" data-trigger="hover" data-toggle="popover">Filter Slopes - </span> <span class="specification-value">12dB Slope (2-pole), 24dB Slope (4-pole), Band Pass, Comb, High Pass, Low Pass, Notch, Resonance</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="LFO" data-content="Low Frequency Oscillator. An oscillator especially devoted to applications below the audible frequency range, and typically used as a control source for modulating a sound to create vibrato, tremolo, trills, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">LFO - </span> <span class="specification-value">6 LFOs</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Control" data-content="Types of external control input and output that allow interfacing with other instruments, synchronizers and computers. Modern synthesizers use MIDI and USB. Analog synthesizers may use CV and Gate signals." data-placement="top" data-trigger="hover" data-toggle="popover">Control - </span> <span class="specification-value">MIDI IN, OUT, THRU</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Arpeggiator" data-content="A device that steps from note to note for whichever keys are pressed (or latched) in a preset or random pattern." data-placement="top" data-trigger="hover" data-toggle="popover">Arpeggiator - </span> <span class="specification-value">7 Algorithms to choose from like up, down, random etc</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Memory" data-content="Storage capabilities for user programmed settings, patches, sequences, waveforms, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">Memory - </span> <span class="specification-value">4 GB Internal Flash memory</span> </div> </div> </div> </div> <span><a title="View user profile." href="http://www.vintagesynth.com/user/406" lang="" about="http://www.vintagesynth.com/user/406" typeof="schema erson" property="schema:name" datatype="" xml:lang="">Naomi Bolton</a></span><span>Fri, 04/09/2021 - 08:49</span> <div class="field field--name-body field--type-text-with-summary field--label-hidden field--item"><p><span style="color: rgb(0, 0, 0); font-family: Roboto, RobotoDraft, Helvetica, Arial, sans-serif; font-size: 13px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; white-space: pre-wrap; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; background-color: rgb(255, 255, 255); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; display: inline !important; float: none;">Quantum is a German-made hybrid synthesizer by Waldorf that was released in 2018. It has three oscillators that each offers five synthesis algorithms. These include Waldorf-style Wavetables, classic synthesizer waveforms, a granular sampler, resonator, and more. Wavetable mode works with preset wavetables, which can also be loaded from an SD card. Waveform mode uses the classic waves while particle mode uses onboard samples. Samples can also be recorded from the rear inputs or imported from an SD card. The power and flexibility of these oscillators make the Quantum one of the most versatile synthesizers available in terms of sheer possibilities. It covers the entire spectrum from classic analog all the way up to digital. Overall, this was definitely a flagship release for Waldorf.</span></p> <p><span style="color: rgb(0, 0, 0); font-family: Roboto, RobotoDraft, Helvetica, Arial, sans-serif; font-size: 13px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; white-space: pre-wrap; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; background-color: rgb(255, 255, 255); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; display: inline !important; float: none;">Waldorf's engineers spent just as much time on the aesthetics of the Quantum to produce an extremely elegant synthesizer. It features a grey metal case, silver aluminum for the trim along the sides and back as well as wood inserts on both sides. It is split into distinct sections and above the 61 keys of the keyboard, you will find the LFO section, the Oscillator section, a large touchscreen display, dual analog filter, and digital filter sections, envelope section, effects section, and output section. The aluminum dials are black and silver with multicolor LEDs to keep things even more organized.</span></p> <p><span style="color: rgb(0, 0, 0); font-family: Roboto, RobotoDraft, Helvetica, Arial, sans-serif; font-size: 13px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; white-space: pre-wrap; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; background-color: rgb(255, 255, 255); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; display: inline !important; float: none;">The screen, which is crystal clear and responsive, is very useful for tweaking parameters, but the sound design is also easy using only the front panel controls. To the left of the keyboard with its high-quality FATAR TP8S keybed is the performance controls. These include the arpeggiator and Chord buttons as well as the Pitch and Mod wheels.</span></p> <p><span style="color: rgb(0, 0, 0); font-family: Roboto, RobotoDraft, Helvetica, Arial, sans-serif; font-size: 13px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; white-space: pre-wrap; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; background-color: rgb(255, 255, 255); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; display: inline !important; float: none;">The rear panel of the Quantum is home to the headphones output, main and out outputs, audio inputs, pedal inputs, USB connections, SD card slot, MIDI In / Out / Thru jacks, and the jack as well as the switch for power.</span></p> <p><span style="color: rgb(0, 0, 0); font-family: Roboto, RobotoDraft, Helvetica, Arial, sans-serif; font-size: 13px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; white-space: pre-wrap; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; background-color: rgb(255, 255, 255); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; display: inline !important; float: none;">While the Waldorf Quantum is not a cheap synthesizer it has more than enough features to justify the price tag. It is an extremely powerful bit of hardware with an excellent user interface and a mountain of options. The stylish design of the Quantum also makes it an eye-catching addition to any studio. If you are looking for something that will help you to unleash your creative potential, then you can't go wrong with the Quantum. </span></p> </div> <div class="field field--name-field-make-er field--type-entity-reference field--label-above"> <div class="field--label">Make</div> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/861" hreflang="en">Waldorf</a></div> </div> <div class="field field--name-field-year field--type-integer field--label-above"> <div class="field--label">Year</div> <div class="field--item">2018</div> </div> <div class="field field--name-field-musical-genre-er field--type-entity-reference field--label-above"> <div class="field--label">Musical genre</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/775" hreflang="en">Electronic music</a></div> </div> </div> <div class="field field--name-field-synth-type-er field--type-entity-reference field--label-above"> <div class="field--label">Synth type</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/779" hreflang="en">Digital</a></div> </div> </div> <div class="field field--name-field-interface-features-er field--type-entity-reference field--label-above"> <div class="field--label">Interface features</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/784" hreflang="en">Modern</a></div> </div> </div> <div class="field field--name-field-format-er field--type-entity-reference field--label-above"> <div class="field--label">Format</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/786" hreflang="en">Keyboard</a></div> </div> </div> <div class="field field--name-field-sound-types-er field--type-entity-reference field--label-above"> <div class="field--label">Sound types</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/791" hreflang="en">Acoustic / Realistic</a></div> </div> </div> <div class="field field--name-field-price-range-er field--type-entity-reference field--label-above"> <div class="field--label">Price range</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/797" hreflang="en">Above $1,000</a></div> </div> </div> <div class="field field--name-field-image-er field--type-image field--label-above"> <div class="field--label">Image</div> <div class="field--item"> <img src="http://www.vintagesynth.com/sites/default/files/2021-03/Quantum_straight.jpg" width="1200" height="386" alt="Waldorf Quantum" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="field field--name-field-files field--type-entity-reference-revisions field--label-above"> <div class="field--label">Files</div> <div class="field__items"> <div class="field--item"> <div class="file-item"> <div class="field field--name-field-link field--type-link field--label-above"> <div class="field--label">Link</div> <div class="field--item"><a href="https://support.waldorfmusic.com/files/Quantum/Manuals/Quantum_Manual_EN_OS_2.0.pdf">https://support.waldorfmusic.com/files/Quantum/Manuals/Quantum_Manual_EN_OS_2.0…</a></div> </div> <div class="field field--name-field-type field--type-list-string field--label-above"> <div class="field--label">Type</div> <div class="field--item">File</div> </div> <div class="field field--name-field-title field--type-string field--label-above"> <div class="field--label">Title</div> <div class="field--item">Quantum Synthesizer User Manual</div> </div> <div class="field field--name-field-description field--type-string-long field--label-above"> <div class="field--label">Description</div> <div class="field--item">Waldorf Music Quantum Synthesizer User Manual</div> </div> </div> </div> </div> </div> <div class="field field--name-field-youtube field--type-entity-reference-revisions field--label-above"> <div class="field--label">YouTube</div> <div class="field__items"> <div class="field--item"> <div class="youtube-field" data-pid="18026"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/Nlt1rGsmXeo.jpg" alt="Embedded thumbnail for Quantum > YouTube" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Waldorf Quantum Demo</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item"> Hunart©</div> </div> </div> </div> </div> </div> </div> <div class="field field--name-field-user-rating field--type-vs-synth-rating field--label-above"> <div class="field--label">User Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="326cae94-7ac3-4eca-9cef-2edc7208778b"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-texture field--type-list-string field--label-above"> <div class="field--label">Texture</div> <div class="field--item">Polyphonic instruments</div> </div> <div class="field field--name-field-disqus-comment field--type-disqus-comment field--label-above"> <div class="field--label">Disqus comment</div> <div class="field__items"> <div class="field--item"><drupal-render-placeholder callback="Drupal\disqus\Element\Disqus::displayDisqusComments" arguments="0=Quantum&1=http%3A//www.vintagesynth.com/waldorf/quantum&2=node/13941" token="j3gC2JrxJKDMksO08BTf2y-aXSbKMcDp8XE3AseWkzk"></drupal-render-placeholder></div> </div> </div></div> http://www.vintagesynth.com/waldorf/quantum |
