Cyclone Analogic BASS BOTT TT-303 V2 - Printable Version +- Vortex Sound Research (http://www.n01ze.com/synthwizards/Forum) +-- Forum: N01ZE World Net News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=45) +--- Forum: World Wide Gear News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=2) +--- Thread: Cyclone Analogic BASS BOTT TT-303 V2 (/showthread.php?tid=17921) |
Cyclone Analogic BASS BOTT TT-303 V2 - SynthWizard - 12-08-2020 Cyclone Analogic BASS BOTT TT-303 V2 <div><span>Cyclone Analogic BASS BOTT TT-303 V2</span> <div class="field field--name-field-specifications field--type-double-field-extended field--label-above"> <div class="field--label">Specifications</div> <div class="field__items"> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Polyphony" data-content="The number of voices (notes) a device can produce simultaneously. Typically, a monophonic device can only play one note at a time. A Duophonic device can play two notes at a time. A polyphonic device can play two or more notes at a time." data-placement="top" data-trigger="hover" data-toggle="popover">Polyphony - </span> <span class="specification-value">1 Voice</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Oscillators" data-content="An electronic device which generates a periodic signal of a particular frequency, usually a sine wave, but sometimes a square wave or other waveform. In an analog synthesizer, oscillators typically produce regularly repeating fluctuations in voltage - that is, they oscillate. In digital synthesis, an oscillator more typically plays back a complex waveform by reading the numbers in a wavetable." data-placement="top" data-trigger="hover" data-toggle="popover">Oscillators - </span> <span class="specification-value">1 VCO</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Waveforms" data-content="A signal, either sampled (digitally recorded) or periodic, being generated by an oscillator. Also, the graphical display of a sound pressure wave over time." data-placement="top" data-trigger="hover" data-toggle="popover">Waveforms - </span> <span class="specification-value">Saw Up, Square, </span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Filter Slopes" data-content="A type of equalizing device for subtractively eliminating selected frequencies from the sound spectrum of a signal and perhaps, in the case of a resonant filter, increasing the level of other frequencies." data-placement="top" data-trigger="hover" data-toggle="popover">Filter Slopes - </span> <span class="specification-value">24dB Slope (4-pole), Low Pass, Resonance</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="VCA/Envelopes" data-content="A shape that changes as a function of time. The shape of a synthesizer's envelope is often controlled by Attack, Decay, Sustain and Release parameters (ADSR). Envelopes can be applied to various aspects of a synth sound, such as pitch, filter cutoff frequency, and overall amplitude." data-placement="top" data-trigger="hover" data-toggle="popover">VCA/Envelopes - </span> <span class="specification-value">1 VCA with Decay envelope</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Controls" data-content="On-board rotary knobs, linear sliders, and push-buttons or switches that may be used to edit various parameters." data-placement="top" data-trigger="hover" data-toggle="popover">Controls - </span> <span class="specification-value">MIDI In/Out, DIN, CV Out, Gate Out</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Arpeggiator" data-content="A device that steps from note to note for whichever keys are pressed (or latched) in a preset or random pattern." data-placement="top" data-trigger="hover" data-toggle="popover">Arpeggiator - </span> <span class="specification-value">1 unique ARP mode</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Memory" data-content="Storage capabilities for user programmed settings, patches, sequences, waveforms, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">Memory - </span> <span class="specification-value">432 Patches RAM / 108 Patches ROM</span> </div> </div> </div> </div> <span><a title="View user profile." href="http://www.vintagesynth.com/user/406" lang="" about="http://www.vintagesynth.com/user/406" typeof="schema erson" property="schema:name" datatype="" xml:lang="">Naomi Bolton</a></span><span>Fri, 12/04/2020 - 08:52</span> <div class="field field--name-body field--type-text-with-summary field--label-hidden field--item"><p><span>As the name suggests, the BASS BOTT TT-303 V2 by Cycle Analogic is another synth that attempted to recreate the famous TB303. However, instead of being a straight-up clone, this synth actually attempted to add a few new features and improvements to the classic original. This is a good thing as the Roland TB-303 is without a doubt one of the most bits of hardware of all time. The TT-303 V2 is not the first time that Cycle Analogic has attempted to replicate the TB-303 either. It is the follow-up to the original TT-303 and some refinements have been made along the way. It's also important to note that the TT-303 V3 is actually a hardware update, not to be confused with the V2 operating system update of the original TT-303. </span></p> <p><span>The most obvious change is that Cycle Analogic redesigned the TT-303 giving it a more elegant and modern look compared to its predecessor. Not only does it have new pots and knobs, but it is also slightly larger and less of a direct clone in terms of the overall design. Another useful update is the ability to customize the colors of the LEDs for things like identifying your patterns. </span></p> <p><span>The TT-303 features a sequencer with 432 user patterns and up to 64 steps per pattern. It also comes with more than one hundred preset patterns divided into nine different styles. In addition, the pattern lab allows for the creation of up to 108 user patterns. Since it uses non-volatile memory no batteries are required for this either. The swing and shuffle can be adjusted to add some extra groove to your productions and for more original bass lines it is also possible to adjust gate length and slide time. Cyclone Analogic also added MUTE and HAMMER features, which can be accessed in recording mode as well as in real-time. The former is designed to imitate the effect of a palm mute with a bass for shorter, less bright steps while the latter simulates a hammer-on or hammer-off action. </span></p> <p><span>Other new features include the Loop Edit and Pattern lab, which is unique modes for creating and editing patterns. Using Loop Edit it is possible to create or edit a pattern while the sequencer is running while Pattern Lab offers extended control over the pattern generator. With it, you can create patterns for your particular style to match the modifiers you used or even your musical key. Finally, it has a unique ARP mode and advanced editing features. </span></p> <p><span>In terms of technical specifications, the TT-303 V2 has one VCO, two waveforms, widely improved audio specifications, and noise floor compared to the original and added outputs. These include CV, GATE, ACCENT, DYN SYNC, Run - Stop, and VCO Out. Even with the large about of Roland TB-303 clones on the market, the TT-303 V2 stood out as a great alternative at a much more affordable price.</span></p></div> <div class="field field--name-field-make-er field--type-entity-reference field--label-above"> <div class="field--label">Make</div> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/1166" hreflang="en">Cyclone Analogic</a></div> </div> <div class="field field--name-field-year field--type-integer field--label-above"> <div class="field--label">Year</div> <div class="field--item">2017</div> </div> <div class="field field--name-field-musical-genre-er field--type-entity-reference field--label-above"> <div class="field--label">Musical genre</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/775" hreflang="en">Electronic music</a></div> </div> </div> <div class="field field--name-field-synth-type-er field--type-entity-reference field--label-above"> <div class="field--label">Synth type</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/779" hreflang="en">Digital</a></div> </div> </div> <div class="field field--name-field-interface-features-er field--type-entity-reference field--label-above"> <div class="field--label">Interface features</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/784" hreflang="en">Modern</a></div> </div> </div> <div class="field field--name-field-format-er field--type-entity-reference field--label-above"> <div class="field--label">Format</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/788" hreflang="en">Desktop / Tabletop</a></div> </div> </div> <div class="field field--name-field-sound-types-er field--type-entity-reference field--label-above"> <div class="field--label">Sound types</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/792" hreflang="en">Drums & Percussion</a></div> </div> </div> <div class="field field--name-field-price-range-er field--type-entity-reference field--label-above"> <div class="field--label">Price range</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/795" hreflang="en">Less than $500</a></div> </div> </div> <div class="field field--name-field-image-er field--type-image field--label-above"> <div class="field--label">Image</div> <div class="field--item"> <img src="http://www.vintagesynth.com/sites/default/files/2020-12/bassbott.png" width="614" height="391" alt="Bass Bott" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="field field--name-field-links field--type-link field--label-above"> <div class="field--label">Links</div> <div class="field__items"> <div class="field--item"><a href="https://www.cyclone-analogic.fr/img/cms/The-Bass-Bot-English-2.0.pdf">Bass Bott Operation Manual</a></div> </div> </div> <div class="field field--name-field-files field--type-entity-reference-revisions field--label-above"> <div class="field--label">Files</div> <div class="field__items"> <div class="field--item"> <div class="file-item"> <div class="field field--name-field-type field--type-list-string field--label-above"> <div class="field--label">Type</div> <div class="field--item">Link</div> </div> </div> </div> </div> </div> <div class="field field--name-field-youtube field--type-entity-reference-revisions field--label-above"> <div class="field--label">YouTube</div> <div class="field__items"> <div class="field--item"> <div class="youtube-field" data-pid="17921"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/yuEzyxHpNyI.jpg" alt="Embedded thumbnail for Cyclone Analogic BASS BOTT TT-303 V2 > YouTube" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Cyclone analogic TT-303 Quick Programming a Pattern in Loop Edit, with TT-606.</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item"> cyclone analogic webstore</div> </div> </div> </div> </div> </div> </div> <div class="field field--name-field-user-rating field--type-vs-synth-rating field--label-above"> <div class="field--label">User Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="30d8b8f6-66ac-43b0-a755-2932c000c149"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-texture field--type-list-string field--label-above"> <div class="field--label">Texture</div> <div class="field--item">Monophonic instruments</div> </div> <div class="field field--name-field-disqus-comment field--type-disqus-comment field--label-above"> <div class="field--label">Disqus comment</div> <div class="field__items"> <div class="field--item"><drupal-render-placeholder callback="Drupal\disqus\Element\Disqus::displayDisqusComments" arguments="0=Cyclone%20Analogic%20BASS%20BOTT%20TT-303%20V2&1=http%3A//www.vintagesynth.com/node/13776&2=node/13776" token="fhjrsZgKsJF44YA62iiQEywKwrvkWk4zY8h3CKR5D74"></drupal-render-placeholder></div> </div> </div></div> http://www.vintagesynth.com/node/13776 |
