Monologue - Printable Version +- Vortex Sound Research (http://www.n01ze.com/synthwizards/Forum) +-- Forum: N01ZE World Net News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=45) +--- Forum: World Wide Gear News (http://www.n01ze.com/synthwizards/Forum/forumdisplay.php?fid=2) +--- Thread: Monologue (/showthread.php?tid=12412) |
Monologue - SynthWizard - 03-08-2020 Monologue <div><span>Monologue</span> <div class="field field--name-field-specifications field--type-double-field-extended field--label-above"> <div class="field--label">Specifications</div> <div class="field__items"> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Polyphony" data-content="The number of voices (notes) a device can produce simultaneously. Typically, a monophonic device can only play one note at a time. A Duophonic device can play two notes at a time. A polyphonic device can play two or more notes at a time." data-placement="top" data-trigger="hover" data-toggle="popover">Polyphony - </span> <span class="specification-value">1 Voice</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Multitimbral" data-content="A synthesizing instrument that can play two or more timbres (also called sounds or patches) at the same time. A typical multitimbral tone generator can play, for example, the brass, piano, and violin parts all at once." data-placement="top" data-trigger="hover" data-toggle="popover">Multitimbral - </span> <span class="specification-value">1 Part</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Oscillators" data-content="An electronic device which generates a periodic signal of a particular frequency, usually a sine wave, but sometimes a square wave or other waveform. In an analog synthesizer, oscillators typically produce regularly repeating fluctuations in voltage - that is, they oscillate. In digital synthesis, an oscillator more typically plays back a complex waveform by reading the numbers in a wavetable." data-placement="top" data-trigger="hover" data-toggle="popover">Oscillators - </span> <span class="specification-value">2 VCOs</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Waveforms" data-content="A signal, either sampled (digitally recorded) or periodic, being generated by an oscillator. Also, the graphical display of a sound pressure wave over time." data-placement="top" data-trigger="hover" data-toggle="popover">Waveforms - </span> <span class="specification-value">Saw Down, Square, Triangle, White Noise</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Filter Slopes" data-content="A type of equalizing device for subtractively eliminating selected frequencies from the sound spectrum of a signal and perhaps, in the case of a resonant filter, increasing the level of other frequencies." data-placement="top" data-trigger="hover" data-toggle="popover">Filter Slopes - </span> <span class="specification-value">12dB slope (2-pole)</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="LFO" data-content="Low Frequency Oscillator. An oscillator especially devoted to applications below the audible frequency range, and typically used as a control source for modulating a sound to create vibrato, tremolo, trills, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">LFO - </span> <span class="specification-value">1 LFO with Saw Up, Square, Triangle </span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="VCA/Envelopes" data-content="A shape that changes as a function of time. The shape of a synthesizer's envelope is often controlled by Attack, Decay, Sustain and Release parameters (ADSR). Envelopes can be applied to various aspects of a synth sound, such as pitch, filter cutoff frequency, and overall amplitude." data-placement="top" data-trigger="hover" data-toggle="popover">VCA/Envelopes - </span> <span class="specification-value">1 VCA with Attack, Decay</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Controls" data-content="On-board rotary knobs, linear sliders, and push-buttons or switches that may be used to edit various parameters." data-placement="top" data-trigger="hover" data-toggle="popover">Controls - </span> <span class="specification-value">MIDI In/Out, USB</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Sequencer" data-content="A hardware device, software application or module used to arrange/sequence timed events into musical patterns and songs. An analog sequencer uses control voltages and gate triggers to control vintage analog devices. A digital sequencer usually uses MIDI and has more advanced capabilities than an analog sequencer." data-placement="top" data-trigger="hover" data-toggle="popover">Sequencer - </span> <span class="specification-value">16-step monophonic sequencer</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Keyboard" data-content="A set of keys or levers, arranged in order of ascending pitch, which enables a piano, organ or synthesizer to be played by hand." data-placement="top" data-trigger="hover" data-toggle="popover">Keyboard - </span> <span class="specification-value">25 plastic mini-keys</span> </div> </div> <div class="field--item"><div class="double-field-extended form-group"><span class="specification-term" title="Memory" data-content="Storage capabilities for user programmed settings, patches, sequences, waveforms, and so on." data-placement="top" data-trigger="hover" data-toggle="popover">Memory - </span> <span class="specification-value">20 Patches RAM, 80 Patches ROM,</span> </div> </div> </div> </div> <span><a title="View user profile." href="http://www.vintagesynth.com/user/406" lang="" about="http://www.vintagesynth.com/user/406" typeof="schema erson" property="schema:name" datatype="" xml:lang="">Naomi Bolton</a></span><span>Thu, 03/05/2020 - 09:45</span> <div class="field field--name-body field--type-text-with-summary field--label-hidden field--item"><p>The Monologue is a monophonic analog synthesizer that was released by Korg in early 2017. It has the distinction of being the last synthesizer designed by Tatsuya Takahashi before switching his role of Chief Engineer of Analog Synthesizer within the company. Although the Monologue is seen as a trimmed-down version of the Korg Minilogue, it has plenty of character of its own.<br><br> The relatively inexpensive price of the Monologue made it a very attractive option for anyone with an interest in hardware synths, but wary of the high prices that they normally fetch. However, although it is a cheaper synth, it does have a surprising amount of power as well as flexibility.<br><br> In terms of design, the Monologue shares a lot of similarities with the Minilogue. It features the same real wood back panel style along with the mini keys and even replicates the inputs and outputs. It is smaller than the Minilogue, though, as it features one less octave on its keyboard. This trade-off is worth the more compact size as well as the ability to power the Monologue with batteries to take advantage of its portable nature. The keys are small, which isn't the best when it comes to playing, but they get the job done. For better or worse the Monologue features the same pitch/mod slider that is found on the Minilogue.<br><br> Taking a look at the architecture of the Monologue reveals that it has two oscillators with each offering three waveforms. It lacks the cross-modulation of the Minilogue, but oscillator Sync and Ring Modulation are present. You also get independent controls for each VCO via the mixer section of the Monologue. Korg has also included their Motion Sequencing technology, so you can record and play back notes as well as parameter values. Volca owners should feel right at home with the 16-step sequencer of the Monologue as it shares a lot of similarities. Unfortunately, the Monologue lacks an arpeggiator, so anyone who needs this feature will have to connect it to a DAW. The upside is that this can easily be done using either MIDI or USB.<br><br> Although the Monologue was released at a time when more and more monophonic analog synths were appearing on the market, it still managed to carve out a nice of its own. The fact that it includes presets that were designed by Aphex Twin didn't hurt its reputation either.</p></div> <div class="field field--name-field-make-er field--type-entity-reference field--label-above"> <div class="field--label">Make</div> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/816" hreflang="en">Korg</a></div> </div> <div class="field field--name-field-year field--type-integer field--label-above"> <div class="field--label">Year</div> <div class="field--item">2017</div> </div> <div class="field field--name-field-musical-genre-er field--type-entity-reference field--label-above"> <div class="field--label">Musical genre</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/775" hreflang="en">Electronic music</a></div> </div> </div> <div class="field field--name-field-synth-type-er field--type-entity-reference field--label-above"> <div class="field--label">Synth type</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/778" hreflang="en">Analog</a></div> </div> </div> <div class="field field--name-field-interface-features-er field--type-entity-reference field--label-above"> <div class="field--label">Interface features</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/784" hreflang="en">Modern</a></div> </div> </div> <div class="field field--name-field-format-er field--type-entity-reference field--label-above"> <div class="field--label">Format</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/786" hreflang="en">Keyboard</a></div> </div> </div> <div class="field field--name-field-sound-types-er field--type-entity-reference field--label-above"> <div class="field--label">Sound types</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/791" hreflang="en">Acoustic / Realistic</a></div> </div> </div> <div class="field field--name-field-price-range-er field--type-entity-reference field--label-above"> <div class="field--label">Price range</div> <div class="field__items"> <div class="field--item"><a href="http://www.vintagesynth.com/taxonomy/term/795" hreflang="en">Less than $500</a></div> </div> </div> <div class="field field--name-field-image-er field--type-image field--label-above"> <div class="field--label">Image</div> <div class="field--item"> <img src="http://www.vintagesynth.com/sites/default/files/2020-02/KorgMonologue.jpg" width="2000" height="2000" alt="Korg Monologue" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="field field--name-field-files field--type-entity-reference-revisions field--label-above"> <div class="field--label">Files</div> <div class="field__items"> <div class="field--item"> <div class="file-item"> <a href="https://www.korg.com/us/support/download/product/0/733/#manual" class="file-title">Korg Monologue Manuals</a><span class="file-description">Korg Monologue Manuals</span> </div> </div> </div> </div> <div class="field field--name-field-youtube field--type-entity-reference-revisions field--label-above"> <div class="field--label">YouTube</div> <div class="field__items"> <div class="field--item"> <div class="youtube-field" data-pid="17361"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/aRhIIPjX9s4.jpg" alt="Embedded thumbnail for Monologue > YouTube (previous revision)" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Korg Monologue (Presets)</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item">3rdStoreyChemist</div> </div> </div> </div> </div> <div class="field--item"> <div class="youtube-field" data-pid="17366"> <div class="field-image"> <div class="field field--name-field-youtube-link field--type-youtube field--label-hidden field--item"><img src="http://www.vintagesynth.com/sites/default/files/youtube/TqZTfY-jWYo.jpg" alt="Embedded thumbnail for Monologue > YouTube" typeof="foaf:Image" class="img-responsive"></div> </div> <div class="wrapper-fields"> <div class="field-title"> <div class="field field--name-field-youtube-title field--type-string field--label-hidden field--item">Korg Monologue full track with effects.</div> </div> <div class="field-author">by <div class="field field--name-field-youtube-author field--type-string field--label-hidden field--item">Magik Tbox</div> </div> </div> </div> </div> </div> </div> <div class="field field--name-field-user-rating field--type-vs-synth-rating field--label-above"> <div class="field--label">User Rating</div> <div class="field--item"><div class="vs-fivestars" data-uuid="aadeb970-caf4-480b-b312-755a0146f761"> <div class="vs-fivestars-stars"> <div class="vs-fivestars-empty"></div> <div class="vs-fivestars-value"></div> <div class="vs-fivestars-hover"></div> <ul><li><a href="http://www.vintagesynth.com/rss.xml#" data-value="1" class="one-star">1</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="2" class="two-stars">2</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="3" class="three-stars">3</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="4" class="four-stars">4</a></li> <li><a href="http://www.vintagesynth.com/rss.xml#" data-value="5" class="five-stars">5</a></li> </ul></div> <div class="vs-fivestars-description"></div> </div> </div> </div> <div class="field field--name-field-texture field--type-list-string field--label-above"> <div class="field--label">Texture</div> <div class="field--item">Monophonic instruments</div> </div> <div class="field field--name-field-disqus-comment field--type-disqus-comment field--label-above"> <div class="field--label">Disqus comment</div> <div class="field__items"> <div class="field--item"><drupal-render-placeholder callback="Drupal\disqus\Element\Disqus::displayDisqusComments" arguments="0=Monologue&1=http%3A//www.vintagesynth.com/korg/monologue&2=node/13216" token="xyg5SbK0YaE97F6m3Jm-JG7gant3rDl4l4eNQV6WgEw"></drupal-render-placeholder></div> </div> </div></div> http://www.vintagesynth.com/korg/monologue |
